Zestawy kołowe - seria 4001
| Produkt | Średnica zewnętrzna D [mm] | Szerokość bieżnika l%3% [mm] | Długość płyty L [mm] | Szerokość płyty B [mm] | Udźwig [kg] | Piasta | Bieżnik |
| IW-K 4001-75X20 | 75 | 20 | 58 | 70 | 50 | stal ocynkowana | guma czarna |
| IW-K 4001-85X25 | 85 | 25 | 84 | 102 | 60 | stal ocynkowana | guma czarna |
| IW-K 4001-100X30 | 100 | 30 | 82 | 100 | 70 | stal ocynkowana | guma czarna |
| IW-K 4001-125X37 | 125 | 37 | 84 | 102 | 80 | stal ocynkowana | guma czarna |
| IW-K 4001-160X40 | 160 | 40 | 104 | 131 | 145 | stal ocynkowana | guma czarna |
| IW-K 4001-200X50 | 200 | 50 | 105 | 134 | 130 | stal ocynkowana | guma czarna |
| IW-K 4001-75X25 | 75 | 25 | 67 | 81 | 50 | stal ocynkowana | guma czarna |
| IW-K 2028-50X22 | 50 | 22 | 48 | 58 | 30 | duroplast (PF) | duroplast (PF) |
| IW-K 2028-75X25 | 73 | 27 | 58 | 70 | 60 | technopolimer (PA) | technopolimer (PA) |
| IW-K 4021-100X30 | 100 | 30 | 84 | 102 | 70 | stal ocynkowana | guma szara |
| IW-K 4081-125X37 | 125 | 37 | 84 | 102 | 130 | duroplast (PF) | duroplast (PF) |
| K0901-001-0087 | 152 | 40 | 104 | 131 | 120 | tworzywo | tworzywo czarne |
| K0901-001-0088 | 200 | 50 | 104 | 131 | 120 | tworzywo | tworzywo czarne |
| IW-K 2042-40X17 | 40 | 17 | 39 | 47 | 30 | technopolimer (PA) | technopolimer (PA) |
| IW-K 2042-50X20 | 50 | 20 | 46 | 58 | 50 | technopolimer (PA) | technopolimer (PA) |
| IW-K 2042-65X25 | 65 | 25 | 58 | 70 | 30 | technopolimer (PA) | technopolimer (PA) |
| IW-K 2042-75X30 | 75 | 30 | 59 | 70 | 100 | technopolimer (PA) | technopolimer (PA) |
| IW-K 2101-32X14 | 32 | 14 | 34 | 40 | 15 | duroplast (PF) | duroplast (PF) |
| IW-K 2101-40X16 | 40 | 16 | 30 | 44 | 30 | duroplast (PF) | duroplast (PF) |
| IW-K 2101-50X22 | 50 | 22 | 39 | 47 | 35 | duroplast (PF) | duroplast (PF) |
| IW-K 4084-100X34 | 100 | 34 | 84 | 102 | 70 | stal ocynkowana | duroplast (PF) |
| K0901-001-0134 | 125 | 37 | 84 | 102 | 80 | stal ocynkowana | duroplast (PF) |
| IW-K 1102-160X50 | 160 | 50 | 100 | 115 | 150 | stal | guma czarna |
| IW-K 2105-50 | 50 | 48 | 38 | 38 | 40 | technopolimer (PA) | technopolimer (PA) |
| IW-K 2105-40 | 40 | 38 | 38 | 38 | 30 | technopolimer (PA) | technopolimer (PA) |
| IW-K 4081-71X25 | 70.9 | 27 | 67 | 81 | 50 | duroplast (PF) | duroplast (PF) |
| IW-K 2028-40X17 | 40 | 17 | 38 | 47 | 15 | guma | guma czarna |
| IW-K 2028-32X13 | 32 | 13 | 32 | 45 | 9 | guma | guma czarna |
| IW-K 1102-150X45 | 152 | 45 | 100 | 113 | 150 | stal | guma czarna |
